Seamless Team Talk
€361,00 €539,00
Prices shown exclude VAT. Shipping costs and applicable VAT will be calculated at checkout based on the delivery country.
  1. ENC Noise Reduction
    • Solidcom SE features an ENC dual - mic noise reduction design. It can dynamically recognize environmental noise with a noise reduction depth of up to 20dB.
  2. Clear Call Quality
    • It offers clear calls, with a frequency response range of 150Hz - 7KHz and a signal - to - noise ratio > 71dB.
  3. Waterproof and Design
    • With an IPX4 - level waterproof design, the overall headphone adopts precise industrial design.
  4. Automatic Frequency Tuning
    • Equipped with an automatic frequency - tuning algorithm, it can automatically adjust the frequency when encountering interference and has a 350m transmission distance without visual - range obstruction.
  5. Easy to Use
    • It is ready to use right after being powered on. It supports up to 5 - way collaborative communication.
  6. Mute Function
    • There are two mute options: the MUTE button and muting by flipping up the microphone boom. The MUTE button supports the PTT mode.
  7. Battery Life
    • The fully - charged headphone has a battery life of up to 12 hours and supports charging while using.
-33%
Solidcom SE-5S (Global Version-2.4GHz)
€361,00 €539,00
-33%
Solidcom SE-4S (Global Version-2.4GHz)
€285,00 €426,00
-33%
Solidcom SE-2S (Global Version-2.4GHz)
€145,00 €218,00
-33%
Solidcom SE Remote Headset Single-Ear (Global Version-2.4GHz)
€73,00 €109,00
Accessories Options
Solidcom SE/SE Pro - USB-C to 3.5mm Cable (1 PCS)
€11,90
Accessory for Solidcom SE / Solidcom SE Pro
Buy on Amazon
Not Sure About Buying?
Free shipping for orders over €80+
Ships same day if ordered by 10AM
24-Month warranty
€361,00
€539,00
Saved €178,00
720-Day Extended Warranty
Free Shipping on €80+
