COSMO C2
COSMO C2
COSMO C2
COSMO C2
COSMO C2
COSMO C2
COSMO C2
COSMO C2
COSMO C2
COSMO C2
COSMO C2
1 / 11
COSMO C2
Redefine Reliability-Wireless Video Solution
€1.199,00 €1.558,00
Prices shown exclude VAT. Shipping costs and applicable VAT will be calculated at checkout based on the delivery country.
Add to Wishlist
  • 2TX & 1RX Solution
  • 3,000ft (1,000m) LOS Range & 33ms Ultra-Low Latency
  • Seamless Frequency Hopping Technology with HEVO 2.0
  • NDI HX3 & HDMI & SDI Ports Support
  • UVC & RTMP Streaming & Multi-Platform Support
  • FPS Booster
  • Fractional Frame Rate
  • Versatile Power Options
  • Customizable Frozen Frame
-23%
Cosmo C2 2TX & 1RX
Cosmo C2 2TX & 1RX
€1.199,00 €1.558,00
-22%
Cosmo C2 1TX & 1RX
Cosmo C2 1TX & 1RX
€929,00 €1.206,00
-22%
Cosmo C2 TX
Cosmo C2 TX
€369,00 €479,00
Accessories Options
Screw Fitting 02
Screw Fitting 02
€9,00
The Screw Fitting 02 is for the use of mounting the Mars 4K or Cosmo C1 horizontally in necessary senarios. It comes a 1/4"-20 mounting thread to mount on to your cage or other gears that come with...
Mushroom Antenna
Mushroom Antenna
€10,91
Compatibility MARS 4K MARS 400S PRO MARS 300 PRO COSMO C1 Features 5 dBi Double High-Gain 90 to 360° Rotating Anti-Pressure 5.8 GHz Transmission Rate Anti-Pressure Material Technology Gold-Pla...
Soft Antenna
Soft Antenna
€14,05
With its flexible stem design, the Hollyland soft antenna can be easily adjusted to different angles, allowing for optimal placement and improved signal strength. Compatibility COS...
D-TAP to DC 2.1 Power Supply Cable
€21,80
Usage: Connect the V-mount battery to power Hollyland video transmission products Weight: 27.5g length: 65 cm
Crab Clamp
Crab Clamp
€15,45
Features Rod diameter: 54mm (2.1") Material: Aluminium Color: Black Compatibility MARS 4K MARS 400S PRO MARS 300 PRO COSMO C1 MARS 400S PRO ll What's in the Box Crab Clamp*1
Not Sure About Buying?
Free shipping for orders over €80+
Ships same day if ordered by 10AM
24-Month warranty
COSMO C2
€1.199,00
€1.558,00
Saved €359,00
720-Day Extended Warranty
Free Shipping on €80+
