Next-Level Team Talk
€4.089,00 €5.111,00
Prices shown exclude VAT. Shipping costs and applicable VAT will be calculated at checkout based on the delivery country.
  • Push-to-Talk Wireless Intercom: Beyond the Walkie-Talkie Experience
  • 24-hour Long Duration: Each Headset comes with an Extra Battery-Never Run Out of Power
  • Active Environment Noise Cancellation
  • Up to 1100ft (350m) Transmission Range
  • Full Duplex Communication
  • Backward Compatible with the First Generation Solidcom C1
-19%
Solidcom C1 Pro 8Set with HUB
€4.089,00 €5.111,00
-20%
Solidcom C1 Pro 4Set with HUB
€2.999,00 €3.749,00
-20%
€2.319,00 €2.899,00
-20%
Solidcom C1 Pro 6Set
€1.775,00 €2.219,00
-20%
€1.179,00 €1.474,00
-19%
Solidcom C1 Pro 2Set
€589,00 €736,00
-19%
Solidcom C1 Pro 3Set
€889,00 €1.111,00
-19%
Solidcom C1 Pro 4Set DH(Double Earmuff)
€1.299,00 €1.623,00
Accessories Options
Solidcom C1 Pro Master Headset
€326,36
Wide Frequency Response for Clear Audio True Wireless Headset, No Bodypack Comfortable to Wear All Day Long 1100' 2-Way Operating Range DECT for Stability and Security Instant Pairing, Easy to Use...
Solidcom C1 Pro Master Headset Double-Ear Version
€389,00
Enhanced Noise Reduction with Dual Microphones Dependable 1.9 GHz DECT 6.0 Technology Cable-Free Headset for True Wireless Experience Dual-Ear Design for Comfortable Fit Clear Audio Performance wi...
Solidcom C1 Pro Remote Headset Double-Ear Version
€369,00
€339,00
Wide Frequency Response for Clear Audio True Wireless Headset, No Bodypack Comfortable to Wear All Day Long 1000' 2-Way Operating Range DECT for Stability and Security Instant Pairing, Easy to Use...
Solidcom C1 Pro Wired Headset for Hub
€129,00
Key Features Connects to Hub via 10-Pin Connector Link up to 8 Solidcom C1 Pro Remotes Two-Mic Environmental Noise Cancellation Reliable 1.9 GHz DECT 6.0 Technology Comfortable Single-Ear Headset ...
Solidcom C1 Pro Hub
Solidcom C1 Pro Hub
€1.635,00
Enhance the functionality of your intercom system by incorporating the Hollyland Solidcom C1 Pro Hub Base. Although the Solidcom C1 Pro system is capable of operating up to 8 headsets without a Hub...
Solidcom C1 (Pro) Hard-Shell Carry Case
€144,55
【Compatibility】Hollyland Solidcom C1 hard-shell storage case is designed for 9-person HUB version wireless intercom headset system and the included accessories. 【Premium Material】The Solidcom C1 h...
€17,27
Frequency range: 1.88–1.93GHz  VSWR: 1.88-1.93G≤2.0  Impedance: 50Ω Gain: 3dBi  Color: Black Weight: Approx. 28.5g (1oz) for each Size: 205x13mm (8.1"x0.5") What’s in the Box? Solidcom C1 HUB...
NP-F550 Battery
NP-F550 Battery
€17,27
Features Rated capacity: 2000mAh Type: Lithium-ion Weight: 100g (3.53oz) Operating temperature: –20℃ to 60℃ Output voltage: 7.2V Limit charging voltage: 8.4V Compatibility MARS 4K MARS 4OOS ...
NP-F750 Battery
NP-F750 Battery
€26,36
Features Rated capacity: 4000mAh Type: Lithium-ion Weight: 205g (7.2oz) Operating temperature: –20℃ to 60℃ Output voltage: 7.2V Limit charging voltage: 8.4V Compatibility MARS 4K MARS 4OOS ...
NP-F970 Battery
NP-F970 Battery
€35,45
Features Rated capacity: 6000mAh Type: Lithium-ion Weight: 300g (10.6oz) Operating temperature: –20℃ to 60℃ Output voltage: 7.2V Limit charging voltage: 8.4V Compatibility MARS 4K MARS 4OOS...
Not Sure About Buying?
Free shipping for orders over €80+
Ships same day if ordered by 10AM
24-Month warranty
€4.089,00
€5.111,00
Saved €1.022,00
720-Day Extended Warranty
Free Shipping on €80+
