4 A Klearer View
€369,00 €590,00
Prices shown exclude VAT. Shipping costs and applicable VAT will be calculated at checkout based on the delivery country.
Add to Wishlist
 KEY FEATURES
  • 4K UHD Video Transmission. Mars 4K is the first 4K video transmission system from Hollyland. It enables sharp and detail-rich images for a splendid monitoring experience.
  • 450ft (150m) LOS Range. The transmission distance of Mars 4K is up to 450ft. It's able to cover a scenery of soccer field size.
  • 0.06s Low Latency. Mars 4K transmits 4K video images in real-time with only a 0.06s delay.
  • SDI & HDMI Support. With SDI and HDMI dual interfaces, Mars 4K is a perfect solution for both DSLRs and high-end cinema cameras.
  • Broadcast & Production Frame Rate. Mars 4K supports decimal-point frame rates to facilitate professional video production at the broadcasting level.
  • Flexible Monitoring Options. Mars 4K allows connection with RXs or mobiles/Tablets. It's able to connect with 2 receivers simultaneously. When connected to one receiver only, the transmitter can connect two phones/tablets via the Hollyview app. If no receivers are connected, Mars 4K transmitter can connect 4 mobile devices in total.
  • Smart Channel Scan & Selection. Stable connection and reliable transmission are available upon startup.  Mars 4K will scan available channels and auto-select the most robust one to build a connection.
  • Multiple Power Supply Options. Mars 4K can be powered up via multiple options, including NP-F batteries, DC Adapter of 6V to 16V, and Type-C charger of 5V 2.5A.
-37%
Mars 4K Kit
Mars 4K Kit
€369,00 €590,00
Accessories Options
1/4"-20 Cold Shoe
1/4"-20 Cold Shoe
€12,04
Feature: mount transmitters or other accessories Material: Aluminum Alloy Weight: 19g Dimensions: 30*25*25*1/4'' (thread 6.3mm)
Mars 4K Transmitter
Mars 4K Transmitter
€189,00 €295,00
 KEY FEATURES Professional Video Transmitter Transmit up to UHD 4K30 Video up to 450' SDI & HDMI Inputs, 5 GHz Frequency Band Smart Channel Scanning, Touchscreen LCD Low 66 ms Latency, 12 Mb/s...
Mars 4K Receiver
Mars 4K Receiver
€189,00 €295,00
 KEY FEATURES Professional Video Receiver Receive up to UHD 4K30 Video up to 450' SDI & HDMI Outputs, 5 GHz Frequency Band Smart Channel Scanning, Touchscreen LCD Low 66 ms Latency, 12 Mb/s Da...
Mars 4K Bullet-styled Antenna
€35,85
The Mars 4K Bullet-style Antenna is a set of antennas intended as spares or replacements for the Mars 4K series wireless transmission system. These antennas operate within the 5.1 to 5.8 GHz freque...
NP-F550 Battery
NP-F550 Battery
€17,27
Features Rated capacity: 2000mAh Type: Lithium-ion Weight: 100g (3.53oz) Operating temperature: –20℃ to 60℃ Output voltage: 7.2V Limit charging voltage: 8.4V Compatibility MARS 4K MARS 4OOS ...
NP-F750 Battery
NP-F750 Battery
€26,36
Features Rated capacity: 4000mAh Type: Lithium-ion Weight: 205g (7.2oz) Operating temperature: –20℃ to 60℃ Output voltage: 7.2V Limit charging voltage: 8.4V Compatibility MARS 4K MARS 4OOS ...
NP-F970 Battery
NP-F970 Battery
€35,45
Features Rated capacity: 6000mAh Type: Lithium-ion Weight: 300g (10.6oz) Operating temperature: –20℃ to 60℃ Output voltage: 7.2V Limit charging voltage: 8.4V Compatibility MARS 4K MARS 4OOS...
Not Sure About Buying?
Free shipping for orders over €80+
24-Month warranty
€369,00
€590,00
Saved €221,00
720-Day Extended Warranty
Free Shipping on €80+
