Mobile Audio Made Easy
€47,00 €89,00
Prices shown exclude VAT. Shipping costs and applicable VAT will be calculated at checkout based on the delivery country.
Add to Wishlist
  • Plug and Play. Lark C1 is ready when out of the box, making it easy to use.
  • Usable While Charging. Both the TX and RX of Lark C1 are equipped with a Type C interface, you can power it up during use. No battery anxiety anymore.
  • Immediate Playback. Unlike similar products, you don't need to remove the plug from the phone to play the recorded audio through the speaker. Direct playback is available and helps to check the audio promptly.
  • Hi-Fi Sound Quality. The sampling rate of Lark C1 hits 48kHz. It keeps rich details of the audio. 16-bit depth provides a perfect dynamic range and better signal-to-noise ratio for video making.
  • With MFi Certification. MFi is the abbr. of made for iPhone&iPad. With this certification, the usage of Lark C1 won't affect the warranty of your iPhone. It'll be a reliable companion in your adventure of creation.
  • Smart Noise Cancellation. With Hollyland's latest wireless transmission technology, you can record crisp audio near or far away from the camera.
  • Ultra-long Duration of 32 Hours. Plus the battery of the charging case, the whole system can work for 32 hours. When fully charged, each transmitter works continuously for 8 hours, covering a full-day recording.
  • 650ft (200m) LOS Range. With Hollyland's latest wireless transmission technology, you can record crisp audio near or far away from the camera.
  • Advanced In-App Operation. Hollyland designed the 'LarkSound' app allowing flexible control over noise-canceling level and input audio volume. The dynamic change of the volume level and the battery status can be checked at a glance.
-43%
Lark C1 Duo / iOS / Cool Black
€56,00 €99,00
-53%
Lark C1 Duo / iOS / Ivory White
€46,00 €99,00
-47%
Lark C1 Duo / Android / Cool Black
€47,00 €89,00
-46%
Lark C1 Solo / iOS / Cool Black
€35,00 €65,00
Accessories Options
Interview Adapter for Wireless Microphones (Handheld/Desktop)
Interview Adapter for Wireless Microphones (Han...
Works with Hollyland Wireless Microphone
€27,00
Dual Use: Handheld & Desktop Stand Designed for Interviews Reduces Wind Noise & Plosives Extendable Handle: Easy to Carry Works with All Wireless Mics Transform your wireless mic into a p...
Not Sure About Buying?
Free shipping for orders over €80+
Ships same day if ordered by 10AM
24-Month warranty
€47,00
€89,00
Saved €42,00
720-Day Extended Warranty
Free Shipping on €80+
