intercom system
hollyland solidcom C1
hollyland solidcom C1 master headset
wireless intercom system
intercom system for home
wireless intercom system for home
hollyland intercom system battery
house intercom system
hollyland solidcom C1 charge base
solidcom C1 charger
hollyland solidcom C1 charger
hollyland charger
Solidcom C1 Hub8S
€3.455,00 EUR
Shipping calculated at checkout.
Order in the next [totalHours] hours %M minutes to get it between and
Description
  • True-wireless headset for 1000‘ line-of-site 2-way communication
  • 150 Hz to 7 kHz frequency response for precise coordination
  • Easy setup with auto-connection right out of the box
  • Enhanced stability and security with DECT 6.0
  • Cascade connections via IP networks, 2/4-wire audio input-output interfaces
  • A/B grouped talk setting
  • Announce the key to mute all the headsets for emergency messages from the HUB base
  • UAC (USB Audio Class) function enables the HUB to join in any cloud meeting on your computer
Add to Wishlist
Hollyland's first true wireless and self-contained headset communication solution with exceptional sound clarity
Take a closer look
The Hollyland Solidcom C1 - HUB8S is a full-duplex wireless DECT intercom system engineered to provide clear audio. It allows for all-day wearing comfort in a true-wireless design with no bodypack required. The system uses DECT 6.0 encryption and dual-antenna technology to ensure secure and reliable transmission at a range of up to 1000'. This makes it well suited for a variety of applications, such as film production, concerts, and public events.
Self-Contained Headset for 2-Way Communication
With no beltpack to worry about, Solidcom C1 offers a highly portable and hands-free coordinating experience. This is perfect for media production teams and others looking for real-time voice communication at distances up to 1000ft
Wide Frequency Response for Precise Coordination
It offers a 150 Hz to 7 kHz frequency response and premium acoustic echo cancellation (AEC) to ensure clear intelligible audio. The directional mic captures the speaker's voice precisely, providing clear conversations even in noisy environments.
Enhanced Stability and Security with DECT 6.0
Built on the powerful DECT 6.0 platform, the Solidcom C1 ensures secured conversation with encryption technology. and You'll have a reliable transmission featuring a dual-antenna diversity scheme.
Ready to Use Right Out of the Box
The headsets pair up automatically and feature tactile buttons for quick adjustments. The microphone boom on each headset rotates 360°, allowing for left or right orientation and easy Mute/Talk switch by a simple push up/down.
Expandable System
The C1 HUB base included in this configuration allows up to eight remote headsets and one wired headset to be used at once. It can interconnect multiple systems to accommodate expanded communication needs via IP networks, and 2/4-wire audio input-output interfaces.
Rechargeable Batteries + Charging Station
Each headset runs on a single rechargeable battery for up to 10 hours per charge. The battery fully recharges in 2.5 hours, and a battery charging station, USB cable, and AC adapter are included.
HUB Base with Additional Features
The included HUB offers additional features including A/B grouping and an Announce key that mutes all the headsets for emergency messages from the HUB base.
The featured UAC (USB Audio Class) function enables the HUB to join in any cloud meeting running on Zoom, Skype, or similar meeting programs via the USB Type-C connection to your personal computer.
The HUB provides three bays, allowing multiple battery power supplies from two NP-F batteries and/or one V-Mount or G-Mount battery (batteries available separately).
*American standard hub is with G-mount.
